Old 02-04-2011, 04:07 PM   #9 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by JasonG View Post
If diesels like it cold, why do some big diesels have intake warmers ? I'll agree it depends on the engine and outside temp. Typically intake manifold temps below 50deg F are less than optimal.
Big rigs have them to aid in starting and engine warm up. In figure 14 of this report http://aerade.cranfield.ac.uk/ara/1937/naca-tn-619.pdf you can see that fuel economy and power increase as intake air temperature go down. All the way down to 26 Degrees F. At -3 Degrees F there is some power loss at lighter fuel settings. The engine in this test was only 14.5 to one compression ratio so with higher compression ratios the peak power for the intake air might be at a lower temperature.
[QUOTE]
Try unhooking your exhaut after the down pipe and let me know how the free running exhaust works for you. Everything has limits. That said, it won't be an issue if he stays with practial pipe size. I have seen trucks that run like dogs with dual 8" straight stacks.
[\QUOTE]
Actually I know people with engines just like mine who have run a straight pipe right out the side after the down pipe. It works great other than the fact its loud and against the law in most states.
I can't speak for the pickup trucks. They probably went with a turbo that is tuned for towing and max power that takes longer to spool.
The larger injectors alow the same amount of fuel to be injected in a shorter time. This causes more to be burnt while the piston is closer to TDC. These engines are individual solenoid operated injectors, not distribution pumps like ours. Totally different animal. They vary pulse width like a fuel injected gasser not stroke length like a dist pump system.
Actually the whole idea behind the Diesel cycle is to keep the combustion stroke at a constant pressure. The closer you approximate this the more power you get per unit of fuel. Trying to get all the fuel to burn near TDC is like the Otto cycle which is less efficient.
