Yup , the fiero was rear engine , rear wheel drive , and are pretty aerodynamic when you get a hatchback mod. I guess thats my backup car incase no plans could work with the other three.
Fino
However I am researching batteries now to try to find out what would be my best option for the electric , want something that doesnt require alot of charging maintenance. As in it will not have memory problems , the shelf life is not really short , I would like something that no matter if it gets ran close to dead it will be fine , and if it gets used barely any it will be fine... It will not get damaged from recharging it at whatever state it was , and the electrolyte will not crystalize from not doing a deep enough discharge often enough.
So I have battery research to do , and I dont know much about them , so I may get turned off on the idea of an electric , and go try to get maximum mpg I can with an ICE
