Old 02-04-2011, 10:37 PM   #17 (permalink)
Winfield1990
Go back and read what I posted...
im not doing the engine for weight distribution thats what the batteries are for , under the floor and in the rear where the rear seats are or are not depending on the vehicle the motor is there to be close to the drive wheels for efficiency and closer to the batteries.
just because the motors closer to the wheels for efficiency thats not because of driveline efficiency and quotations around a falsely quoted quote is a great way to get your point across..... btw...
Efficiency due to traction , efficiency due to weight saving by not having as big of mechanical parts to make connections to the wheels. efficiency without a term coming before it is a general term.
Also "That means that the batteries are right next to the motor, right? Or is your car circular in shape?"
you got the first part of my quote right just to ask a question , but only in a sarcastic manner you obviously do not know the meaning of a real quote because you did not use it in any meaningful way so I wil ASSUME SO.... but if my car is infact like I already stated and you quoted on just above... the batteries are next to the motor , what would the circular shape of the car have anything to do with changed how the batteries are next to the motor ?
you cant change a true statement with an off the wall question...
example:
the cat is black right? , its raining outside so is it still black? NICE QUESTION clev , need to start asking the questions at the beginning of the conversations before their already answered by the poster.
and I am still here just to point out your misundestandings and assumptions , and now... whatever you say im gone. only reason besides pointing out the above.... Was I was looking in control panel for an account deletion check box or link which I cannot find.
So please , whoever is in the charge of the forum , please erase my account. Not just block , or cancel , but remove please. Thank you and im sorry for this rubbish being applied to your forum. There was no disrepect for the forum on my part done on purpose.
