frank ????? The size is the same, even if you can measure it corectly of not. Its seems you want to change the discusion about the size of the patch, to your ability to measure it. Secondly I run my tires at 45 psi. when i said the best tires was a skinny tire, i was refering to FE only. Which is what this site is about. You might be right, but it doesnt affect the conversation. The conctact patch is the same, whether you can measure it accurately. the best tire for FE is a skinny tire. even if you have to air it to 50 psi.
