Old 02-05-2011, 07:42 AM   #7 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I'm not sure what eco-friendly means in terms of using a chemical product like polyester or epoxy resin.
From the user point of view, probably the most eco-friendly thing that you can do is to learn to use as little adhesive as possible and still get the job done. Avoid coating surfaces with epoxy and use as little glass as much as possible. Having said that, glass and epoxy is an amazing building material.
I get my boatbuilding epoxy from raka.com, it is cheap and a high quality product.
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
Cd (02-05-2011)
