Originally Posted by catchonfire
Can anyone point me to instructions for doing this overlay on my own?
catchonfire,the lowest tech solution,and the one I'm forced to use,is to actually photocopy enlarged images of vehicle and template at same scale,tape the template over the vehicle photo where max roof camber positions line up,then actually take a straight pin and pierce the template through to the image below.
When you separate the two,light will shine through the pinholes,revealing the template trend line,and a french curve can be used to 'connect the dots.'
It's dirt simple,requires no computer and can be accomplished with a few simple drafting instruments.
I work in 11" X 17" scale.For better accuracy,you can photo-enlarge to a greater scale and just tape the paper together.
It's kinda Fred Flintstone technology but it will get you to the party.
