Old 02-06-2011, 08:04 AM   #54 (permalink)
discovery
discovery's Avatar
Originally Posted by Artric View Post
The chargers have a variable set point which marks the highest that it will charge to. I usually set it around 177, because that's higher than I've seen a pack go. It doesn't charge at this rate, but rather the current voltage of the battery. A constant current/variable voltage power supply is used to give it a "swing" of 39v. Therefore, at a max of 177, it will charge as low as 138v (which is actually 1.5v higher than what is given to the battery, as that is lost from diodes).
Thanks for the good info.
Once the HV Battery reaches 177V after charging it for many hours, for how long do you top it off? Also, what is DC fuse?
Thank you
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
