Originally Posted by wakinyantanka
Isn't this were the sot-227 mini bloc style mosfets come into play? I think they can be mounted directly to the surface of the heat spreader without thermal pad material and you have a larger area on the back of the mosfet itself.
Please correct me if I'm wrong as this is the approach I'm taking with my build. ![Smile](/forum/images/smilies/smile.gif)
I've seen reasonable diodes in that package, but not good MOSFETs.
Avnet has a good price, $18.53, on the STPS200170TV1 diode in an ISOTOP package. That's 200A at 170V, which should be good for up to 150V traction voltage (the diode sees lower peak voltages than the MOSFET).
