Originally Posted by watercat
I don't think were talking about a security kill switch, at least I'm not. a switch to let you coast with the engine off. It just happens mine is hooked to my clutch pedal starter switch and it takes some practice to use it. just stepping on the pedal turns off the cam signal and I would think no one would ever figure it out. some times it gets me.
i had a security kill switch on my honda, actually it was 3 switches total. 1 to interrupt the starter, 1 to interrupt the ignition, and a third to kill the fuel pump. i also had a fuel cut-off valve and a relief valve that would recirc the fuel if the pump was running when the valve was shut. all of it was hidden so there was virtually no way to steal my car, short of towing it. you could have a kill switch for EOC that could be used for security as well, depending on how you wired it and where you placed it.
