very helpful post jimbob! the camquest tool (on the comp cam site) lists the attributes slightly differently: what is the lobe centerline and how does it relate to lobe separation angle mentioned above? I realize I'm probably oversimplifying here, but could you condense the 3 attributes you mentioned into their effects on low end torque vs high rpm horsepower? thanks
