Old 02-07-2011, 07:37 PM   #11 (permalink)
The Rooster
He ain't gonna die!
The Rooster's Avatar
Tree Catcher - '94 Acura Integra LS
90 day: 32.12 mpg (US)
The Old Dog - '92 Honda Accord LX
90 day: 31.58 mpg (US)
Originally Posted by some_other_dave View Post
Since gasoline is roughly 7.5 lbs/gallon, he'd have to have a pretty large tank to shed 76 lbs! I'd basically be empty in my CRX (mechanically pretty close to the 'Teg) if I left 10 gallons out of it.
BTW, I recommend against removing the ABS. Going lighter is good and all, but ABS is a Very Good Thing Indeed (TM). It could save your life someday, or at least your front bumper/hood/radiator support.
-soD
The ABS in broken. It was diagnosed as the Pump Motor Accumulator Thing ™ which is a very expensive part. With labor, it's over $1000 to fix it. And I'll bet the whole thing weighs 50 pounds, between the computer, that big ole pump, the sensors, wiring harness and all the extra lines and extra fluid. I'm planning to jack the non-abs parts out of a junk yard 92-95 Civic or Integra RS to "fix" the ABS on the cheap. From what I understand, that early ABS system is crap when it works anyway.
She was beating on my door for two hours last night...but I wouldn't let her out.
