Old 02-07-2011, 06:56 PM   #68 (permalink)
aerohead
if
Originally Posted by 3-Wheeler View Post
Thanks Phil,
I wonder if this could have helped with the Insight Tail Extension project?
Seriously, it looks really nice! I downloaded a copy.
Jim.
Jim,the upper curvature is the same but a smidge cleaner so it really hasn't changed.
The belly reflects what SAE would recommend for any new car design.At SAE test weight ( 300-lbs ) added to car,it's not supposed to suffer a ground strike anywhere.
We can go below it,but it's got to be 'active',with some sort of facility to 'react' to a threat and move into a 'safe' position until danger passes.
So anyway,I think what you've is basically spot-on.She's a 'LOOKER'!!!!!!!!!
I do like the EPCOT car that GM did,and at some point I'm going to do some 'active' stuff.
Can't wait for weather to improve and see how the Insight's new booty does.
