Absolutely!
Edit: I've been spending an inordinate amount of time on putting that stupid precharge circuit on the control board, and making the board bigger and more expensive, when I realized, there is a perfectly good mounting board directly below the control board that is larger. I can just have the precharge stuff mount right there! Hurray! Now the thru-hole control board is like 6.5x2.5" or so, so it's a lot cheaper. By the way, MR Bigh, that's what the hold up has been for me sending it to you, since i've been changing so much stuff on it.
