Old 02-08-2011, 06:50 AM   #69 (permalink)
max_frontal_area
insignificant
Originally Posted by jamesqf View Post
Perhaps this is already answered somewhere, and I missed it, but why go to the trouble of compressing air when you already have a large volume of hot gas under pressure, flowing out the exhaust? Just duct it to the appropriate places, making sure that it doesn't get into the cabin...
the amount of of tailpipe "jet propulsion" on a gasser is negligible. how do i know? i am glad you asked. cycled in traffic for many years. during the winter it is easy asses - especially if lightly dressed. on a bicycle you are quite sensitive to temperature specifically temperature fluctuations. imagine this if you will,
balancing behind a car at a stoplight which has its tailpipe pointed backwards.
awaiting the moment the car "launches" as SUV jockeys love to do, you do the same, providing you posses the skill and power to stick to the object for as long as you can. while feeling the air that has rushed around the car and joined with exhaust gases it is imperceptible to notice a temperature difference from the ambient air.
lets move up into diesel territory. 22:1 compression of a normally aspirated low compression diesel vs. 9:1 for an engine using spark plugs and a fuel which was specifically formulated not to combust.
the diesel dumps twice the air out the back! add a turbo running 15 psi or perhaps 30 on a modded engine. hmmmm!
pack in behind a pickup running that much boost and although they almost invariably have exhaust pipes pointed to the side or an angle now you can begin to feel the heat. on a large truck (class a and b) 3 atmospheres of boost are not uncommon and if somebody did their homework on aftercooling and decided utillize air to air charge cooling instead of using engine coolant you are actually feeding your engine oxygen molecules instead of hot air.
now you have something! however, this phenomenon only happens during periods of high boost. at crusing it once again becomes negligible besides big rigs and a lot of pickups shed their exhaust out the top. now if you consider
the enormous wake a large truck leaves behind everything gained by what i mentioned above and running the exhaust to the very rear pointed into the wake zone it all becomes peanuts again. UNLESS of course turbo chargers are re-utillzed to produce boost at all times instead of just being on demand power adders!!
if approached a like a complete system, carefully integrating all airflow related components such as always on engine cooling fans (which can use up to 50 horsies! on big rigs) various other heat exchangers of which i counted no less than EIGHT on a 2007 super duty, integrating airflow from all other componentry which sheds heat, the best up to date body aero design and naturally all external aero enhancements and bolt ons available to date,
high pressure relief ducting, and of course proper exhaust augmentation which is FINALLY being exploited - quite beautifully on F1 racers. along the way targeted CFD and finally wind tunnel verification. throw in some FE based driving clinics, because quite frankly the truckers i rode with drove
just like truckers speak
i feel tremendous change could be affected with careful approach and design
but one will have to STEP OUT to make it happen.
i know bigevilmart would buy 10mpg rigs
