Old 02-08-2011, 12:09 PM   #4 (permalink)
asimmons04
97 Eclipse Spyder
Note: I would not do this unless your engine is INLINE, and EACH cylinder has ITS OWN injector. Otherwise you will get vibration no matter which cylinders you kill, and there will always be SOME fuel going to ALL cylinders unless its MultiPort fuel injection. Then you'll just run lean and knock and probably burn everything up...just saying.
