CapriRacer, thanks for getting my head screwed on straight. Now that I think about it more, since the contact patch needs to be the same size for a given load & pressure, a wider tire will have less sidewall deformation. The patch area is WxL; if W is more then L must be less. And I suppose less deformation results in lower RR.
Well written article BTW
![Wink](/forum/images/smilies/wink.gif)
