Originally Posted by abell75
............Now that I think about it more, since the contact patch needs to be the same size for a given load & pressure.....
I think there may be data to refute this.
............ a wider tire will have less sidewall deformation. The patch area is WxL; if W is more then L must be less. And I suppose less deformation results in lower RR......
But I think the issue of less deflection due to the larger load carrying capacity is true, but I think the size of the fottprint is not connected in a way that can be used in any quanitative way.
............Well written article BTW
Thanks
