Old 02-09-2011, 11:55 AM   #13 (permalink)
nimblemotors
EcoModding Jack
nimblemotors's Avatar
Don't use a crankshaft, they are heavy and inefficient.
A drysump means you can run the oil pump using an electric pump instead of engine power and make more HP.
Not necessarlly. It all depends on the design and intended use. However, most are over designed.
Less volume of oil in the crankcase = less windage = less hp to spin the crank = more overall hp
Using a extra quart oil pan with one less quart of oil helps to achieve this without loss of original intended capacity.
