Old 02-09-2011, 12:02 PM   #15 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Perhaps a micro switch in the throttle linkage or one activated by a vacuum dashpot and you could set it to trip a relay and only run when the engine is at light throttle or high intake vacuum. A simple mechanical adjustment could set the threshold. One problem with trying to charge a fairly discharged battery with the alternator is that the windings can get very hot reducing it's service life.
Personally it sounds like a lot of work for little benefit.
Noah Webster, 1787
