Old 02-09-2011, 04:07 PM   #12 (permalink)
ConnClark
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Originally Posted by Julian Edgar View Post
Certainly not what I understand to be the case. Can you produce some references?
One very informative paper I keep referencing is
http://aerade.cranfield.ac.uk/ara/1937/naca-tn-619.pdf
in figure 8 they show power output with boost pressure for fixed fuel increments per cycle.
In figure 10 they show what a restriction of air intake does to performance.
in both cases the more in the cylinder results in more power out and higher efficiency for a given quantity of fuel.
