Old 02-09-2011, 05:13 PM   #4344 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
There was one SR board back in August that I messed up on the low voltage cutout for the high side driver (or low side, or something like that). I could send you one of those piles of crap if you want. It's surface mount resistors and capacitors, but through-hole ICs and stuff.
Jeff! with your money, I'm going to order a 3/8"x3/4"x ??? bus bar and test the melexis current sensor. Initial calculations using the equations in an application note showed that it only has to be 1/16" above a 1" wide bus bar, but I'm not going to do a wider bus bar, so I need to do it for a 3/4" wide bar. I figured it's better to keep the inductance down, since the current will be so high.
kits and boards
