Originally Posted by UFO
That analogy doesn't make sense. Let's stick to engines.
I fail to see how it does not apply. Making modifications to your vehicle is somehow more or less justifiable depending on what part you are working on? Just replace adding a boat tail with advancing the timing if that helps you understand.
I'll let you re-invent the wheel. I already know what happens when I reduce the octane of my fuel.
I'm sorry to hear you have those kind of problems with your vehicle.
Maybe you should read a few more threads, and judge for yourself.
I plan to do just that.
