Originally Posted by redpoint5
It would be minimal, but forcing exhaust through a radiator or other heat exchanging path would induce back pressure.
Suppose that "heat exchanging path" had exatly the same geometry on the inside as your current exaust system?
I fail to see the advantage of exhaust heat used for heating the cabin.
I guess exept for allowing your engine to warm up faster it would be completely useless..
