Old 02-10-2011, 11:10 AM   #19 (permalink)
Arragonis
The PRC.
The pressure drop is good. I meant the accell tests.
Just a thought, is the standard intake plenty for a 1.9 litre engine only revving to 4500 rpm? If it was a petrol screamer then maybe that would release more power with this mod.
Also do you have any idea of increased boost pressure actually reaching the engine ? I'm wondering if the turbo / relief valve combination more or less sets the boost level at WOT no matter how much extra air the intake is allowing. If you restricted the intake then that would have a negative effect obviously.
