The Citroën 2CV also has a feature that could be a useful example: it uses a centralized dampener for both the front and rear suspension. If this was combined with a hydraulic *spring* system that also does the dampening, then much more energy could be regained, maybe?
So, how could this work? How much energy could be regained do you think?
The 2CV system was designed to keep the car level with the long suspension travel designed to cope with the rural roads of 1930s France - the original design spec said a basket of eggs should be placed on the rear seat and driven across a ploughed field. So the energy gained at one end when the suspension was compressed was used at the other end to raise the suspension - result = car stays level = better ride.
The 2cv was also very light, so if you captured the energy how would this be done ? Batteries are heavy although I have read the posts on aero vs weight for better MPG ?
