What voltage are you now running? Assuming the dishards are rebadged odysseys then its a great battery. I ran a 120v pack of them for a year. Only complaint was the weight! One thing i would say was when i spoke to enersys on this side of the water they said the warranty only applied to engine starting applications.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
