Hi again, I did reply earlier but site maintainance didn't allow text to be posted. Anyhow. Its done 105,000 miles appx. I did notice a drop in oil. A phone call to Vauxhall tech told me, you can't use Bio diesel.
Ecoxantia, thanks for info. Does number 3 have a purpose? I always used to crank the engine, till it started.
I notice that the top grill allows air flow over the top of the radiators, ( 3 rads here, coolant, air con and Inter cooler), missing them altogether. The lower grill seems to be the main opening to keep the rads cool. Should I block the top grill? Also, the top half of the Inter cooler, AC rad and Main rad, doesn't receive cool direct air, as the front bumper blocks it. So theoretically only the lower half cools properly. Whats your view on this, please?
Thanks
Mike
