Old 02-16-2011, 12:15 PM   #49 (permalink)
Arragonis
The PRC.
Originally Posted by 320touring View Post
Gearing and engines issues there around maintaining the "acceptible rate of accelleration" desired by the public, and smaller engines. smaller lumps need shorter gears to keep levels up?
Could the adoption of an "Eco 5th" to ALL cars drop highway/A road consumption?
According to something random I came across a while ago it takes just 18hp to push a Ford Sierra along at 70mph. It takes many times that much to accelerate or climb hills, and nothing at all to descend. So for a mid-sized car (say Ford Mundano in the UK / Ford Fusion in the states) I think the changes could be :
1. Lower weight for composite panels, lighter seats etc etc.
2. Smaller engine - TSI style 1.4 Turbo, 120-170hp.
3. 6 Speed gearbox with loooong 6th.
4. Free-wheel, like old Rovers and SAABs used to have for built in coasting ability.
Take the three states a car typically runs in.
Flat cruise - engine runs like a 1.4 NA with long gearing.
Accelerate / Climb - turbo adds torque required temporarily.
Decelerate / Descend - free wheel allows engine to drop to idle.
For the last one if the box is auto or semi auto then maybe the box could slip into a long gear to go into DFCO mode depending on the rate of deceleration.
None of this is expensive and all of it exists / could be made easily.
Someone could even do it as a project here.
* What is the cost of a turbo vs Hybrid stuff in terms of weight and money ?
* What is the power / torque output of a 1.4 petrol at idle ?
