Electric clutch for mechanical fan?
I read that electric fans are less efficient at cooling than mechanical fans. Converting motion to electricity & back to motion again.
Has anyone with a mechanical fan thought about making an electric clutch instead of using the thermal clutch? It could use the same controls as a single speed electric fan.
I think you would want to use a light weight fan blade to control the weight & accelleration. I have never taken an AC pump apart to know how much the clutch wieghs, or if the clutch could handle the instant torque it will see.
What are your thoughts?
Don
