Old 02-17-2011, 11:53 AM   #48 (permalink)
roosterk0031
I don't think I mess with trying to swap engines, you can change sprockets much cheaper, and effectively get to the same place.
Break it in and get a good baseline, go up one tooth front sprocket, probably all you can do to clearance issues. The chain will probably still work, then start going 2-3 teeth smaller on rear sprocket, if you go too far you may have to shorten the chain.
