To answer the question:
Yes, your speedometer will be wrong. (I know this math is not quite right, but it's close). It will read LOW by a percentage approximately equal to the increase in circumference of your tires: 2/14= 14%
So when going 57, you will see 50 on your gage
When going 114, you will see 100
Like others have said, there are many topics posted already. Opinions are mixed; some say the added rotational inertia cancels out the improved final drive ratio, others have positive results.
like almighty bmw stated, you need the circumference of the TIRE not the wheel, to make the calculation.
Reason: the TIRE, not the WHEEL.
