Old 02-17-2011, 11:26 PM   #5 (permalink)
jamesqf
Originally Posted by almightybmw View Post
Won't help. Metal weighs more that rubber doesn't it?
Depends on how thick the metal & rubber are. I don't have numbers, but it seems possible that a larger, lightweight rim could weigh less/have lower rotational inertia that a smaller rim with a heavy tire.
Also, as the OP said, if the tire diameter is larger, it could effectively lower the gearing, which could be an advantage if he does a lot of highway cruising.
Then there's the question of tread width: wider tread means higher rolling resistance.
