Old 02-18-2011, 07:29 PM   #7 (permalink)
redneck
Check the fuel pump pressure. Also check if fuel pump is pumping enough volume. You may have a restriction in the tank. If so you may be able to back blow the fuel line with air.
Try asking your question here.
Honda | Acura Research, Reviews, Performance Parts, Owners - Honda-Tech.com
