Old 02-19-2011, 02:41 PM   #4 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I see you've got a Scangauge installed, and it's an automatic. If she can get it into top gear TC lockup early and just cruise at 60 all the way on the freeway, she should be somewhere between the mid-30s and low 40s mpg. Watch the rpms on acceleration, trying to keep them below the shift/TC slip rpm shift to 2500 rpm. Every time it kicks down, your mpg tanks. City stop & go is where you get your worst mpg, so coasting through lights and coasting well in advance of stop signs will gain her a lot of mpg. The other big killer is high speeds. The closer she can stay to the 55-60 mph range, the higher her trip mpg will be. It's very significant. Try a 5 or 10 mile drive on the same route at 55 and again at 70 mph. You'll see a 10 mpg difference between the two.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
this guy (02-21-2011)
