Old 02-19-2011, 07:33 PM   #28 (permalink)
watercat
The green machine - '94 Geo Metro
Is there a advantage when i'm running a mpg test to do it on a full moon and if there is besides down what diretion should i head.
ran another test today and found that i was able to maintain highway speed and not start the cars engine as long as i had not reach the bottom of the mountain.
conclusion: best fuel economy is mountain driving so far. I never run the test going up the mountain i dont like the results as much. I am now considering adding a magnet to a tow bar like they use to pick up nails from parking lots. the idea is to pull in behind a semi truck in his blind spot and let it connect with his loading dock pumper. its standardized so it should work on all steel trailers. not only will it help the mpg but its a decent autopilot for taking a break to get of here and check your email. my gps will tell me when to tapp the breaks to release myself when i get to my off ramp. EV should be using this to have a drive wheel alternator charging the battery pack up.
