Old 02-19-2011, 09:08 PM   #75 (permalink)
NHRABill
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
Sounds like you need to change the rear gear ratio.. You will then have easier less stressful starts and actually be able to use 5th. Do the Math when the tires are mounted on the car measure your tire height get your rear gear ratio and look up the transmission gearing ratios get to calculating many online tools to help you there and find out what speeds each gear will be used for. Changing the Diff gear is easy compared to the swap you already did or bring it to have someone do it for you gears are cheap and its an easy job.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
