Clean your engine to chassis ground connections. Also battery terminals and both of the other ends of the battery cables. Make sure the battery is working properly. It should have enough reserve to turn the headlights on for 20 minutes (with the engine off) and still start the engine and run properly.
regards
Mech
Reason: changed 2 minutes to 20 minutes
