Originally Posted by animated_zombie
Hey everybody,
Anywho just got to building a grille block last night. It's just a mock up, but I'm going to see how this tank of gas goes, and then modify it. I was thinking once I get it where I want it, maybe making it out of lexan?
i would definitely put the block on the front of the grille as said earlier, doing that would give you a place to put the front license plate where you can see the entire plate (some states get pissy about that). you can then use the corex (or coroplast, whatever you prefer) to make basic air ducting from the chin opening up to the radiator and then block or unblock parts of the lower opening as required based on outside temps
