How about this for an idea, put the windows near upright, so they are on the front instead of the top of the cold frame, the sun is still really low in the sky even at noon, so if the windows were at the front instead of the top they would let alot more light in and thus heat it up faster, if you have enough windows and bales and another indoor out door thermometer you might try so you can compare the two.
