Old 02-21-2011, 07:46 PM   #26 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Electric hot water heaters tend to use more energy over all and cost more to run, going to a forced vent gas hot water heater shrinks the flu size because it has a fan that pulls the flu gases out instead of relying on natural draft or you can go even further like I plan to do and get an A.O. Smith Vertex, the flu in that only goes half way up the tank then spirals back down exiting the bottom, 90% or 96% efficient depending on what one you get, electric hot waters just burn the natural gas at the power plant, so why not burn the natural gas where you need it?
Originally Posted by johnlvs2run View Post
An electric tank has no chimney, so the reheating can be greatly reduced. Also I can put an electric tank on a timer, with or without a thermostat. Recently I found the following link that shows how to convert a gas water heater to electric, which I am planning to do very soon.
IWillTry.org » Convert your gas hot water tank to electric
