First pizza pan made with my own cutter
. Tolerance is +-1mm at the moment, but I have to make better thing to hold the sheet on place than that two sided tape. Its not holding strong enough.
DIY Pizza pan cutter.jpg - Windows Live
Havent installed the radius gauge/tape yet, but that should not be a problem. cutting quality is the same as my subcontractors CNC milled FleXcaps. It should be because I am using the same 6mm milling head as they do
Maybe I will even build a electronically rotating table then it will be really pro machine
