If you are going to use the hex inverting thing anyway, why not just invert the signal, adn then feed that signal into 4 different hex inverters? Or if you are going to add the hex inverters, why not just add a little op amp circuit instead, which can then supply like 200mA, and be following the exact signal as the input?
