Old 02-22-2011, 03:48 PM   #21 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
As I find the time and money, I'm going to be revisiting this... since my '86 Golf diesel doesn't have an ECM, etc, it could technically run with NO electrical load at all!
If I can find a way to do it, I want to remove the electric solenoid from the injection pump, and replace it with a manual shut-off to kill the engine.
Then, rewire the alternator so that it will only charge based on brake usage or battery voltage (in the case that the battery gets low, such as night driving or times when the lights need to be on during the day.)
There's already no radio, so aside from various sensors which turn on lights in the gauge cluster based on specific events, there literally is no electric load beyond the fuel pump itself.
So little load, in fact, that a small bank of batteries will be necessarily placed onboard because the main battery(ies) will likely get overcharged, or the alternator itself will provide no braking effect due to the SOC of the main battery(ies).
