Thread: It's working...
Old 02-23-2011, 04:49 AM   #2 (permalink)
Jim-Bob
Junkyard Engineer
Jim-Bob's Avatar
Super-Metro! - '92 Geo Metro Base
$250 Pizza Delivery Car - '91 Geo Metro Base
90 day: 43.75 mpg (US)
Fronty the wonder truck - '98 Nissan Frontier XE
The thing with EOC is that you really need a manual transmission to do it. Doing it in an automatic can kill the transmission because some of the bearings need the pump to be running in order to feed them. I do a ton of EOC in the 5 speed Metro and it really does pay off. However, you do need to choose your moments and remember that you will have only 2 or 3 brake applications before it runs out of vacuum assist. You will also lose power steering. This isn't a problem in a manual steering Metro, but could be quite scary in a larger PS equipped vehicle if you do not pick your place carefully. You also will want to leave the key on and hold down the clutch and leave it in a gear that you can bump start from. In a Metro, that is 3rd or 4th. Any lower and it gives the drivetrain a nasty shock due to how the car is geared. As they say, your results may vary.
No green technology will ever make a substantive environmental impact until it is economically viable for most people to use it. This must be from a reduction in net cost of the new technology, not an increase in the cost of the old technology through taxation
(Note: the car sees 100% city driving and is EPA rated at 37 mpg city)
