Old 02-24-2011, 11:50 AM   #35 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
JacobAziza, thanks for your feedback. You're inspiring me to do more.
Originally Posted by sid View Post
I still have a tank electric hot water heater. I have it hooked up to a water heater timer where the timer portion is off. I strictly use the timer as a manual on/off switch for my water heater, which saves stress on my breaker. I only turn on the hot water heater shortly before taking a shower. I turn it off just before stepping into the shower.
I have my hot water heater temperature set so that if I shower with only hot water, no cold water turned on at all, the shower water is a comfortable temperature. This is about 112 degrees F, as indicated by the markings on my water heater thermostat, which I'm sure aren't too accurate. In the winter when it is in the 30's F, I find I need to run the heater about 18 minutes for a comfortable shower. In the summer here in Florida, I don't have to run the heater at all for a comfortable shower. My hot water heater is located in my attic, which helps in the summer, since attic temperatures heat the water.
I haven't used hot water for laundry for decades. Consumer Reports claims the most effective laundry detergents are the ones formulated for and used with cold water.
Sid, thanks for the helpful details! I'm going to do the same thing with my water heater.
How do you determine the temperature, just by feel the way it comes out?
Another thing will be trying the cold water laundry, and using less laundry soap.
Do you have a particular recommendation for brand?
