Old 02-24-2011, 06:27 PM   #15 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by zonker View Post
for example, the white rag gets better mpg from a 2.25" dia. aluminum tube (with 144cc injectors) between TB and MAF, and gets more power when i use a 2.75" dia. tube (with 168cc injectors). the smaller tube increases air velocity thru the maf sensor which advances timing and enriches fuel (which i lean back out with the slightly smaller than oe 152cc injectors).
Something we are forgetting is harmonic tuning, Diameter and length can affect this. If you have the length to put a long pipe out your intake this does make a very significant effect on power/fuel usage and has nothing to do with intake restriction. Throttle body spacers do this to a very small degree as well. Now if the length could vary with RPM we would have a winner as the effect could then span the RPM band.
Cheers
Ryan
