Old 02-25-2011, 03:02 AM   #6 (permalink)
frankydevaere
Originally Posted by Old Tele man View Post
...a real-world "working" model yet?
...bet, the constantly moving "center-of-gravity" will rival the gyroscopic problems of the WWI Gnome engines!
Gyroscopic, centrifugal and inertia forces are all three different things.
No, center of gravity stays in place, always on the main center line of the crankshaft. Pistons and conrods are moving symmetrically away and together, balancing inertial forces ( of the first and second order ) and centrifugal forces.
The gyroscopic force ( in case of flying or driving a motorcycle ) of the alu rotor, alu cylinder , torlon bearing houses and steel drive mechanism is not worse or better than of an conventional engine with a flywheel. The rotor is rotating 5 times slower than the crankshaft and has 12 ignitions per revolution. That is five times slower rpm than a "gnome" or a "rhone"
Nevertheless, all the rotating parts are heavier than a wankelrotor but still light and rotates 4 times slower than this wankel ( wankel 3 ignition per revolution )
real working ? , yes a spinning toy ( kind of RC )
this one ? 750 cc i'm working on.
