Old 02-25-2011, 10:06 AM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by sjr View Post
if you were going to build a car from scratch for high gas mileage would you go low to ground? high above road? or what? , Im thinkin 2 person car, use geo metro components , thinkin tandem seating , I can build fiberglass molds and parts so any shape is possible , under 1500 lbs, under 1000 lbs ideal
Go low and reduce the amount of air going underneath the car.
You can go up and try to get out of the drag-inducing ground effect, but it brings along other problems :
- reduced stability ;
- outriggers for wheels adding weight, more wet area and drag, multiple aero bodies in rather close proximity cause complex interactions
- reduced useful volume
- structurally more complex
- less car-like
