Originally Posted by AeroModder
I took it out on the highway for the first time this morning. 5th gear runs the engine at 2400 RPM at 55 MPH. Not too bad, but taller tires might help some.
When you get taller tires, does the odometer or something else have to be adjusted for the mileage to be accurate, because you're traveling more distance with each revolution of the wheels?
