Thank you for the definitions
This is a big help. The conversions aren't things where the numbers can be looked at, and view numbers that I understand.
I'm using a data logger to monitor the data that has the ability the convert the raw values for me, including the fault bits. And I'm going to try to use it for the battery pack monitor, and charging also. It isn't cheap, but it's somethig that I understand and can add and change where I want to.
Don
